I'm trying to send a command via the API, for example I want to activate the feature "oneTimeCharge".
I tried to send such POST request:
Sending the above with a valid Bearer Token does return:
Where is my mistake?
You need to send a json request payload with every command. This is also true for commands with "empty" parameters, so you need to send just an empty json object. Also, make sure to have the correct request payload mime type, i.e. the "Content-Type" header has to be "application/json". Postman sets this header automatically for you if you enter a request payload and select "raw" and "json" from the two dropdown boxes like shown in the attached screenshot:
The problem was solved by @phildaub23 while the Developer part of the forum was created!
I used a.) a wrong URL (https://api.viessmann-platform.io...instead of https://api.viessmann.com..
and b.) missed the empty body ("{}") part.
In JavaScript that looks like.
headers["Authorization"] = "Bearer "+ token;
var url ="https://api.viessmann.com/iot/v1/equipment/installations/"+ installationID +"/gateways/" +gatewaySerial + "/devices/0/features/heating.dhw.oneTimeCharge/commands/activate";
//logger.info("url: {}", url);
var returnvalue = HTTP.sendHttpPostRequest(url,"application/json", "{}",headers,2*1000);
Did you use POST and "Content-Type: application/json"? In this case params is "{}" of course.
Thanks for the answer.
I did use POST and tried it also with the header Content-Type application/json.
So far I did not put in any PARAMS for the POST request, using just the url as posted above.
The result is always as the above posted (first) error message.
I'm using POSTMAN to test-send such messages.
