Domain Change for the Viessmann API
As part of the continuous optimization and modernization of our services, we are currently in the process of switching our applications and websites to the new domain viessmann-climatesolutions.com. This change will also affect the domains for resources such as the Developer Portal and the API Documentation.
For your integrations, this requires the following technical updates:
1. API Endpoints:
2. Identity and Access Management (IAM):
3. API Response Body:
  • The uri value within the JSON response from the Features API (/iot/v2/features/...) will reflect the new viessmann​-​climatesolutions.​com domain in the future.
The API endpoints under the new domain are already available, and we ask you to please use the new addresses with immediate effect. The old viessmann​.com domain will be deactivated during Q4/2025, by the end of the year at the latest.
We understand that these changes may require adjustments to your existing code. To assist you in this process, we recommend referring to the API documentation.
Support Channels:
If you have any questions or require further assistance regarding these updates, please don't hesitate to reach out here in our forum or send an email to [email protected].
We appreciate your understanding and cooperation as we continue to improve the Viessmann API.
5 ANTWORTEN 5
ich nutze aktuell in iobroker den Adapter viessmannapi.0
Leider kann ich hier nirgendwo die neue API URI ändern.
Wie ist das vorgehen um auch weiterhin in iobroker auf meine Daten zugreifen zu können.
Vielen Dank!
Hallo, bin ich der einzige der noch nicht gefunden hat wie ich das im ioBroker Adapter anpassen kann.
 Vielen Dank für Eure Unterstützung.
Hallo @jochensch44 , eine neue Redirect URI kannst du im Dashboard Bereich des Developer Portals einstellen: https://app.developer.viessmann-climatesolutions.com/
Dort wird unter "Your clients" dein API Key angezeigt. Daneben befindet sich ein Knopf zum Editieren des API Keys, unter anderem lassen sich dort neue Redirect URIs einstellen.
Probier es einmal aus. Ich hoffe, es hilft dir weiter.
Gruß,
Michael
Hallo @CustomerCareMichael, vielen Dank für die Rückmeldung. Wenn ich es richtig verstehe, füge ich beim API Key die neue URI hinzu (siehe Screenshot). Passt das dann so?
Vielen Dank und viele Grüße
Jochen
Hi @jochensch44 , du müsstest natürlich auch in deinem genutzten Code schauen, dass bei den API-Aufrufen nur noch die neue Domain genutzt wird. Wenn du ein Plugin von Home Assistant, ioBroker oder ähnlichen verwendest, stelle sicher, dass dort die Anpassungen vorgenommen wurden, bzw. dass du auf die neueste Version updatest.
Michael
