I recently purchaced a Vitocal 60-A boiler and I want to integrate it in Home Assistant to achieve to goals:
1) use my PV energy when I have overproduction
2) shut-off the boiler when I'm using to much grid energy (to prevent spikes which cost money in Belgium).
In the manual of the 60-A I see a 'F-Connector' used for PV installation and after some searching i found the cable (ZK02660) which can be used to short pin 1 and 2 to instruct the boiler to 'overheat'.
In the manual of the Vitotronic I see a 4 pin connector also used for heatpump installations with a matrix to select 4 modes (contact 1/contact 2):
- open-open --> normal
- closed-open --> power off
- open-closed --> increase to set temp
- closed-closed --> increase to max temp.
Mode 3 seems to match with what is achieved with cable ZK02660 although that closed pin 1 and 2.
Questions:
- is the F-connector the one that would also be connected to a Vitotronic?
- Does the Vitocal 60-A also supports these listed 4 modes?
- If it supports is, is it correct that pin 1/2 equals floating contact 2 (D) as described in the manual of the vitotronic and pin 3/4 contact 1 (C)?
- If this is the case, is my assumption that for instance using a shelly 2P could be used to direct the Vitocal 60-A remotly in one of the 4 modes?
Hello mhaket,
the functions of your DHW heat pump cannot be equated with the functions of the Vitotronic control unit.
Many greetings
4 |
