Good day Gents,
I belong Vitocal 222G & Vitocell 100 E, wish is working very well. When I have problem, you are the man who solved problems. Now all is Ok, just have a question. Summer time my Vitocal 222G is working only for hot water. How to heat water - by heat pump or with electricity ? Which way is cheaper ?
Thank you in advance
Best regards
Ned
Hi Ned
the el. power consumption is always cheaper when you use the heatpump.
In Germany al ot of people have their own solar power plants with overcapacity in summer.
They use partly the heating element, because it works without wear and spare lifetime of the compressor. and the homemade el. power is for free.
When making hot water with the heat pump you should start the boiler schedule at a time of the day when you usally expect the highest outside air temperature. eg. In Germany after 1 p.m.
If the capacity of your boiler big enough it would be o.k. to enable the hot water only from 1 p.m. to 4 p.m.
5 |
