Leider spreche ich nicht genug Deutsch, um eine Frage auf Deutsch stellen zu können. 😞
I have a Vitocal 200_S AWB_M-E-AC 201.E10 heat pump and I wanted to adjust the power of the electric heaters. Unfortunately, this is not possible through the ViCare app. I also installed ViGuide but since I'm not a service technician, I don't get access to change the settings.
In order to adjust the power of electric heaters, the repairman must come in person and, of course, charge for it.
Is there any possibility that I could adjust the power of the heaters myself? Maybe through web access, api calls?
Or perhaps with a setting in the service module?
Danke für eure Hilfe, Grüße Dušan
I assume you have a 200-S with One Base Control.
Here you find the service instructions:
6199961VSA00006_1.pdf
Inside the service menu on the HMI of the IDU (see p. 41) you can adjust the power parameter 2626.0.
The configuration parameters 2340.x to enable or disable the heater are accessable during commissioning procedure.
Normaly you do not need the Heater. Too expensive. If you have no Success with the Software, disconnect the Heater. Open Front Cover, Top of Electric you see the main Cables for the Heater and the 2 gray Color big Power Relais.
Pull at each Relais one primary Cable. Now the Relais will not work.
Unfortunately, my device doesn't have such a menu. I'm attaching pictures of what happens after I enter service menu.
Enter Service menu
And now I get only this:
I'm not sure what will happen if i enter "Commissioning" menu.
You are right, even though it is written in the service manual of Vitocal 200-S it seems the service menu is not available till now.
Gelöst: Viessmann Climate Solutions Community - Viessmann Climate Solutions Community
But during commissioning it is possible to disable the heater.
2nd picture: Gelöst: Viessmann Climate Solutions Community - Viessmann Climate Solutions Community
Because I have a Vitocal 250 I cannot help with more details. During commissioning procedure on Vitocal 250 the heating curve will be reset. I assume it is the same for Vitocal 200-S. You have to set it again.
Unfortunately, there is no way to adjust the power of the heaters, only to turn them off. I don't want to do that.
It's probably possible to adjust this only via the app ViGuide, but since I'm not a repairman, I can't use it.
Whatever I choose, when I want to add a new device (i try with everything with "heat pump", I get the response that this device is not supported.
Ask a friend with basic knowledge to help you by electric disconnect/disabling.
He is able to turn off the heater. But he wants to adjust the power for some reason.
Adjust ?
When ?
In the Range of Percent ?
Sorry, bin jetzt am Ende mit meinem Englisch. Die Goldstandard Lösung wäre es die Heizstäbe per EXTERNER Phasenanschnittsteuerung Prozentgenau zu fahren. Ich habe ja eine kleine externe Unterverteilung nur für die Heizstäbe, wenn ich da noch eine Phasenanschnittsteuerung rein setzen würde, dann wäre "alles" möglich. ON-OFF oder 10-90 % stufenlose Leistung. Momentan kann ich per 3 Automaten 33-66-99 % oder Off.
Aber ICH habe ja ne WP gekauft und keinen Durchlauferhitzer - also OFF.
Der TE benötigt ganz klar einen Elektriker...
Letztlich möchte er den Paramer 2626.0 einstellen. Bei den A25x geht das im Servicemenü, bei den 200ern nicht. Dort kann das wahrscheinlich nur der HB über ViGuide.
Dann soll er mal einen Elektriker bemühen der meine Installation "nachbaut".
Es ist SOO einfach. Nur die 3 Phasen der drei Heizer von Extern aus schaltbar ausführen.
Dann hat man/er : 0% - 33% - 66% - 99% Leistung einfach per Finger am Automaten abrufbar.
Wäre die Einstellbarkeit an der WP nicht noch einfacher? Sie ist ja vorgesehen und möglich.
Klar, mit ner guten Software wäre Vieles besser, aber es fehlt so viel in der Software.
Ich erinnere nur mal an die WW Bereitung meiner 200-S:
Volle Pulle oder nix, man kann die Leistung der WP bei der WW Bereitung nicht nennenswert runter regeln.
Beim Heizen kann sie es... 🙄
Ein Nonsens hoch3. WW Bereitung mit PV - hallo, da ist mir die Laufzeit vom Verdichter egal, egal ob mein WW in 10 oder 100 Minuten heiß ist. Die Peakleistungsreduzierung der WP wäre wichtig.
Kann die Software nicht.... 30% Verdichterleistung bei WW haben die Programmierer nicht vorgesehen.
Da ist was dran, aber vielleicht weiß ja doch noch jemand, wie man bei der 200-S in Eigenregie den Parameter setzen kann.
Er hat die neue Version - ich bin raus.
| 7 | |
| 7 | |
| 6 | |
| 6 | |
| 4 |
