Since a couple of months my flat is heated by a VITOCAL 222-S, AWBT-E-AC 221.C08 together with Energycal Radiant heating elements. I am quite happy with it, were it not for a low frequency hum noise, which becomes most noticeable at night (by neighbors too, unfortunately ...).
For night operation, I have already activated the "Reduced Noise" option, and tried both levels, but not much success. I believe it might be related to an acoustic resonance within the gas pipes (about 13m), which appears to set in when the inverter operates at a frequency somewhere in between 30 to 40 Hz. Is there some way to set some service parameters as to explicitly exclude this frequency range during "Reduced Noise" operation ? Consider also that at nights I do not need full performances, as I set most of the Energycal elements to Radiant operation only (let us say that during night I am probably using not more than about 1kW average).
Thanks, Best Begards
Luca
Alternatively, if it were possible to actually fix a specific inverter frequency value to be held constant during "Reduced Noise" operation, at 20 Hz my plant configuration is extremely quite. Here are the parameters captured when the electric input power is about 1.3 kW:
On the following pictures you can see what it should look like. Unfortunately, I can't tell you where you get the fixation clamps from.
But since you are certainly entitled to a warranty on the execution of your specialist company, I recommend that you contact him again. Then he should do the work correctly.
Fastening the refrigerant lines:
■ Only attach the refrigerant lines with pipe clamps with a soft elastic insulation insert (EPDM).
■ Attach the pipe bend for vibration compensation directly behind the pipe bend (towards the outer wall).
■ Refrigerant lines at a distance of max. fasten 2.0 m with pipe clamps. We recommend fastening the refrigerant lines at a distance of 1.5 m using pipe clamps.
■ We recommend installing pipe clamps only on components with a surface weight of ≥ 250 kg / m2.
Best regards ° fl
