Riscaldamento solo acqua solo con elettricità
Hello,
I have a Viessmann Vitocaldens 222-F hybrid with heat pump (222.A29).
In your opinion, if I want to reach 50 ° in the domestic hot water tank, is there a way to use only electricity?
Thank you.
John
Hello John,
as the maximum flow temperature of the heat pump is only 55°C, this can be difficult.
Many greetings
