Can I upgrade Vitocal 222G & Vitocell 100 E with solar system for hot water DHW ? Any advice ?
Good day,
I would like to ask - can I add solar system to my Vitocal 222G & Vitocell 100 E. I noticed that summer time use around 10Kwh ( usualy working hours heating system 1,5 hrs / 24 hrs) per day just for DHW (hot water). I am trying to reduce mountly bill for electricity. Could you advice what kind of solar system to connect and is it possible to do it with my already mounted Vitocal 222G & Vitocell 100 E.
Thank you in advance
Ned1
5 ANTWORTEN 5
Hello Ned1,
a retrofit kit for a solar thermal system doesn't exist for your compact heat pump. But it would be possible to optimize the operation of a photovoltaic system. If you tell me the serial number of your heat pump, I can tell you exactly how this would be done.
Best regards ° fl
Dear Herr Schneider,
The number is 7501985301130102.
Regards
Ned1
You would be able to trigger various PV functions using a PV system and a 3-phase energy meter connected to the heat pump control via Modbus. For example, a setpoint increase of the hot water temperature.
Best regards ° fl
Thank you very much for replay. Could you advice with links for Modbus and other hardware I need for this project.
Best regards
Ned1
Under the following link you will find the assembly instructions of the 3-phase energy meter.
https://www.viessmann.com/vires/product_documents/5516060VMA00001_1.PDF
PV energy meter 3-phase - order number 7506157
Best regards ° fl
