How old is my Boiler and can I trace the seller path (what is seller or what is the re-seller)?
Good Day!
1. How to know , how old is my boiler ? I have a serial number (16 numbers - 7970019400736104) and read the article here (https://www.building-center.org/viessmann-hvac-age/) that 8 digit mean the year of boiler production date? Is it correct? If yes, in my case, what the year is? 2000, 2010, 2020? Or maybe 2024?
2. Is it possible to know the seller or reseller by Serial number or where boiler is initially purchased. Our Viessmann technician said that boiler comes directly from the Germany, but we have local re-seller. Is it possible to check?
2 AKZEPTIERTE LÖSUNGEN
Hallo @Sergio_Mr
Your Vitodens 100-W B1HF-25 3.2-25kW 7970019 was manufactured in 2024.
Hello @Sergio_Mr
Unfortunately, I cannot answer your second question because I do not have access to this data.
Greetings
3 ANTWORTEN 3
Hallo @Sergio_Mr
Hi @divanc !
Thank you very much for your prompt reply ! What about my second question? 🙂 Is it possible to track seller or re-seller?
Thanks in advance!
Hello @Sergio_Mr
Greetings
