Umwälzpumpe - Replacement WILO VIHUE/1-5 / 7339372
Hello
My circulation pump is broken and needs replacement. But i cannot find the right replacement product
I have the following
Typ: VIHUE/ 1-5 / 7339372
Nr: 4505781 /0235.6
Viessmann heater is Vitotronic 100
I cannot find the number of the divicon - but i have the packing numbers 5331506 /5331508 / 5331509
Thanks in advance
Balder
6 ANTWORTEN 6
Hallo
Wilo-Umwälzpumpen-Ersatz für Divicon, siehe Link.
https://www.viessmann.com/etapp/parts/de/0500/7858002?source=%2Fetapp%2Fparts%2Fde%2F0500%2F7516400%...
Schöne Grüße
Is there any alternative, this model is sold out everywhere
Thanks
Balder
Are there any alternatives? This model seems to be out of stock everywhere
Thanks
Hallo
Es gibt einen W-HE SC mit Flansch und er hat die Bestellnummer 7874714.
Schöne Grüße
Thanks, i can find 7874717 - but this one is without flansch, would you know the flansch bestellnummer?
Hello
You can use the 7874717 pump head with the existing flange of the old VIHUE/1-5 pump.
The new one is on the link
https://www.loebbeshop.de/viessmann/ersatzteil/pumpenmotor-w-he-sc-mit-flansch-7874714
greetings
