Vitovent 300-W Luftventilatoren Drehzahl
Hi,
Sorry for not writing in German.
I have a Vitovent 300-W with LB-1 controlling unit in operation since October 2018.
I recently noticed that at Level 3 (195 m3/h in/out) the supply air fan runs 650 RPM faster than the exaust fan.
Neddless to say, the ducting was done in a workmanlike manner, the vents  are of an appropriate shape and size, and the filters are regularly replaced.
Is this normal?
undefined
9 ANTWORTEN 9
Hello AirKna113,
the Vitovent 300-W can automatically regulate pressure differences. If there is a slight icing on the heat exchanger, the speed of the outside air fan is increased by the control. The fact that it comes to a slight icing, is normal, about the regulation also recognizes when the preheater must be turned on for outdoor air heating.
Best regards ° fl
Seat Flo_Schneider,
Thank you for your response.
I forgot to mention that when I checked the system the outside temperature was well above zero degree Celsius and that no preheater is installed. I understand that the Vitovent adapts the speeds of the two ventilators to maintain the airflow settings but, in my case, I think the difference is too high (even if no default message is displayed and the device apparently is working well).
The Vitovent 300-W has a standard preheater installed. Was the difference on your ventilation unit since the commissioning so big?
Best regards ° fl
As of your question, I'm sorry, I don't remember. Considering that a possible cause can be attributed to the different type of filter used for the intake (F7) and for the expulsion of air (M5), earlier today I replaced them with two M5 filters. Nothing changed: there is a ~ 600 RPM difference, yet.
Regards.
Did you check the air heat exchanger once? Maybe this is very dirty and is clogged from one side.
Best regards ° fl
Earlier today, I removed the "Gegenstrom-/Enthalpiewärmetauscher". It was clean and not damaged.
If the pipes, filters and the heat exchanger are clean, there may still be a defect in the fan motor. I recommend you to contact your heating contractor.
Best regards ° fl
Thank you. I'll take your advice.
Ciao.
Hello AirKna113,
Ich habe ein ähnliches Problem. Haben Sie es jemals geschafft, dieses Problem zu lösen? Ich kann keine Lösung finden – das Regenerieren/Ersetzen der Lüfter ist das Letzte, was ich noch nicht versucht habe
Hier gibt es mehr in meinem Thread:
https://community.viessmann.de/t5/Lueftung/Lauter-Betrieb-hohe-Geschwindigkeit-des-Zuluftventilators...
