ich mal wieder.
Wenn bei der Inbetriebnahme der Ölkessel auf Gas (03) gestellt wurde, hat das Auswirkungen auf den Ölverbrauch bzw. die Brennstv. Anzeige, die sich aktivieren lässt über die Codierung (hat hb nämlich nicht aktiviert.
Annette
Hello,
Anyone feeling responsible for answering this.
If the heating which is oil based has been set to gas like 03 will that have an impact on the 'internal calculation' which you can activate via the manual?
Since this was not set correctly during the first-time-run.
Incredibly lack of support here in the forum, with the builder and from Viessmann as well.
Heating was taken live in Mai 2023.
This maintenance agreement is not what is legal. Either you earn money by maintenance and this involves all parts, or you don't. Then you cannot ask for 24/7 Network connectivity and that is the crucial point - how are you and the owners of heating guaranteeing that - is it just impossible - maybe check your IT department once more....
