Vitovalor PT2 of aug 2019, message F.195 12F0 94
Vitovalor PT2 installed in AUg  2019, message F.195 12F0 94, message remains even after switching off-on the mains.  What could be the reason ?
5 ANTWORTEN 5
Hello patrick_VB,
with message 12F0, the fuel cell has a lockout. In this case, the exhaust system and gas supply must be checked by one of our service technicians. Please contact your specialist company so that the order can be placed.
Best regards, Robin
Hi Mr Robin, yes i'll do it, i feel a bit desappointed that something happens so quickly 😞
Thanks for your qucik reply
Patrick VB, Brussels
Hello patrick_VB,
I can understand your disappointment, but maybe it's just a little thing.
Best regards, Robin
To keep the communitry informed :
Technician came, no default at all found - testing also exhaust gas, etc
The message 12F0 cannot be ignored, even if no trouble remains. A physical (Panasonic) hardware reset is required by the technician before the Panasonic element can work again.
No part was changed !
Software update was made after deep analysis of the SD card content, no trouble at all was reported ( to me )
I'm not convinced by the analysis, we will see...
Thanks
Patrick, Brussels
Hello patrick_VB,
thanks for the feedback. The update provides the basis for the fuel cell. The SD data are analyzed by Panasonic, which results in measures for troubleshooting. The colleagues from Belgium know what they are doing.
Best regards, Robin
